Use the following procedure to display the next hop for the logical interface.
- Select the Logical Interfaces NextHop tab.
Logical Interfaces NextHop Field Descriptions
Use the data in the following table to use the Logical Interfaces NextHop tab.
Name |
Description |
Id |
Shows a unique value that identifies the logical interface tunnel. |
Ip |
Shows a unique value that identifies the next hop IP address of the logical interface tunnel. |
DestIfIndex |
Shows the next hop destination interface index to reach the next hop IP of the logical interface tunnel. |
DestVid |
Shows the next hop destination VLAN ID to reach the next hop IP of the logical interface tunnel. |
